I thought I'd try the Ford truck Motor Mounts while I was Fixing Stuff.. First off.. The Hole is not 7/16 like the write up says.. it's 1/2 Inch.. So you have to Drill Bigger than Expected.. Not a big Problem.. It lifts the Motor Up by more than 1/2 inch.. First Time I checked for clearance, Everything fit.. HOWEVER.. When I put the Hose Clamps on the Intake tubes, I left the Screw at the Top of the motor, and slammed the hood!.. OOOPs.. I now have Worm Clamp Dents going OUT on my hood.. ($h!t) Other than that little mistake, I like them.. It gives me a little more room under the motor at the Rack, and gives a little more clearance beside the Plenum to work.. Just DON'T have the Worm Clamps on the top of the tube and all will be good.. I think they are only like $20 each Cj
